hello i send here my program in such way so it can not compiled but if i put the last two modul in vise versa ,i mean delay_time befor timer0 interrupt it is compiled please help message error is error 45: undefined symbole (pass-2) thanks for all; hamidi
//------------------------------------------------------------------------------ // Header files //------------------------------------------------------------------------------ #include <AT89x051.H>//header file for 892051 #include <STDIO.H> // Standard I/O header file #include <stdlib.h> //------------------------------------------------------------------------------ // Value Definitions //------------------------------------------------------------------------------ #define TRUE 0x01 // Value representing TRUE #define FALSE 0x00 // Value representing FALSE #define ON 0x01 // Value representing ON #define OFF 0x00 // Value representing OFF #define HIGH 0x01 // Value representing ON #define LOW 0x00 // Value representing OFF //#define DELAY_BLINK 1500 // Value for delay time - blink //------------------------------------------------------------------------------ // I/O Port Defines //------------------------------------------------------------------------------ #define SDATA P3_2 // Serial data #define SCLK P3_3 // Serial clock #define LOCK_DETECT P1_7 #define ALARM_LED P1_6 #define BUS_FAULT_LED P1_5 #define LIVE_LED P1 //------------------------------------ // Procedure: initialize_system // Inputs: none // Outputs: none //------------------------------------------------------------------------------ void initialize_system (void) { TMOD=0x16; TH0=0; TL0=0; ET0=1;//TIMER 0 INTURRUPT ENABLE TR0=1;//START TIMER 0 IT0=0;//EXTERNAL INTURRUPT 0 IS FALLING EDGE EX0=0;//ENABLE EXTERNAL INTURRUPT EA=1; } //////////////////////////////////////////////////////////////////////////////// // Routine: delay_time // Inputs: counter value to stop delaying // Outputs: none // Purpose: To pause execution for pre-determined time //////////////////////////////////////////////////////////////////////////////// void timer0 (void) interrupt 1 { static unsigned char idata var1=0; static unsigned char idata var2=0; if(++var1==255) { var1=0; if(++var2==13) { var2=0; read_from_8046(); } } TF0=0; EA=1; } void delay_time (unsigned int time_end) { unsigned int index; for (index = 0; index < time_end; index++); }
Looks like you are using the Assembler to translate a C source. C files are translated with C51, not with A51.
now a TRIPLE posting, IGNORE
Hamidi, I do not understand your code. Seems to have some syntax errors in it. Regards
