i am using the nrf24E1 board, i transmit the data through serial port and display on PC through hyperterminal, now i want that i have to give some data to the board through serial port and watch the display on PC so please check my code and inform how can send data to board from PC. #include <Nordic\reg24e1.h> #include <stdio.h> static volatile unsigned char idata rxbuf[32]; // Uart recieve buffer static volatile unsigned char rxrp; // Uart receive buffer read pointer static volatile unsigned char rxwp; // Uart receive buffer write pointer static volatile unsigned char rxn; // Number of characters left in receive buffer static volatile unsigned char idata txbuf[32]; // Uart transmit buffer static volatile unsigned char txrp; // Uart transmit buffer read pointer static volatile unsigned char txwp; // Uart transmit buffer write pointer static volatile unsigned char txn; // Number of characters left to send void DELAY_LOOP_Wait(const unsigned int ); const char hex_tab [] ="0123456789ABCDEF"; void Init(void) { TH1 = 243; // 19200@16MHz (when T1M=1 and SMOD=1) CKCON |= 0x10; // T1M=1 (/4 timer clock) PCON = 0x80; // SMOD=1 (double baud rate) SCON = 0x50; // Serial mode1, enable receiver TMOD = 0x20; // Timer1 8bit auto reload TR1 = 1; // Start timer1 P0_DIR |= 0x02; // P0.1 (RxD) is an input P0_ALT |= 0x06; // Select alternate functions on pins P0.1 and P0.2 EA =1; } void Serial (void) interrupt 4 using 2 { if (RI) { RI = 0; // Clear receive interrupt bit rxbuf[rxwp] = SBUF; // Store received character in receive buffer rxwp = (rxwp + 1) & 0x1f; // Advance write pointer rxn++; // Increment number of characters in buffer } if (TI) { TI = 0; // Clear transmit interrupt bit txn--; // Decrement number of characters to send if (txn > 0) // More characters in transmit buffer? { SBUF = txbuf[txrp]; // Yes, store next character in uart buffer txrp = (txrp + 1) & 0x1f; // Advance read pointer } } } void PutChar(char c) { while(txn > 31) // Wait while transmit buffer is full ; if (txn == 0) // If all previous characters are sent... { SBUF = c; // ...write character directly to the uart... txn = 1; } else { txbuf[txwp] = c; // ...else write it to the transmit buffer txwp = (txwp + 1) & 0x1f; // Advance write pointer ES = 0; // Disable serial interrupt while... txn++; // ...incrementinfg numnber of characters to send ES = 1; // Enable serial interrupt } } unsigned char GetChar(void) { char _getkey(); unsigned char c; //PutChar ('a'); while(rxn == 0) // Wait until there is at least one character in the buffer ; c = rxbuf[rxrp]; // Read next character from buffer rxrp = (rxrp + 1) & 0x1f; // Advance buffer read pointer ES = 0; // Disable serial interrupt while... rxn--; // ...decrementing number of characters in buffer ES = 1; // Enable serial interrupt return c; } /*void PutChar(char c) { while(!TI) ; TI = 0; SBUF = c; }*/ void PutString(const char *s) { while(*s != 0) PutChar(*s++); } /*void DELAY_LOOP_Wait(const unsigned int DELAY) { unsigned int x, y; for (x=0; x<=DELAY; x++) { for (y=0; y<= 12; y++); } }*/ int main(void) { Init(); { while(1){ //DELAY_LOOP_Wait(10); switch (GetChar()){ case 'a': PutString("MY Own Board !\n"); break;} } } for(;;) ; return 0; // ; }
ready-made and working code here; http://www.keil.com/download/docs/200.asp Please follow the instructions on how to post code!
