I know my MAX487EESA UART Transeiver chip is sending data to the recieve pin on the F320, as I can watch high and low activity on the scope. The baud rate needs to be 460800 from my device and I have it configured to 24Mhz sysclock, with a TH1 value of 0xE6. As far as I can tell I have configured everything correctly. The following code is a stripped down version to just load an array to see values. There should be at least all sorts of different values but all I get is 0x00 and 0x80. Can anyone help?
#include <cygnal\c8051f320.h> void init_UART(void); void Oscillator_Init(void); void Port_IO_Init(void); void Reset_Sources_Init(void); sbit SMBUS_Selection = P1^5; sbit SPI_Selection = P1^6; sbit UART_Selection = P1^7; unsigned int temp[50]; unsigned int v; void main() { SMBUS_Selection = P1^5; SPI_Selection = P1^6; UART_Selection = P1^7; P0 = 0x00; P0MDOUT = 0x00; // Sets P0 to open drain P2 = 0x00; P2MDOUT = 0x00; PCA0MD &= ~0x40; // Disable Watchdog timer EA = 0; // Enable global interrupts Port_IO_Init(); Reset_Sources_Init(); Oscillator_Init(); // Setup SYSCLK to 24 MHz if (UART_Selection == 0) { init_UART(); while (1) { while (RI0 == 0); RI0 = 0; temp[v++] = SBUF0; if (v == 49) v = 0; } } } void init_UART(void) { TMOD |= 0x20; // Timer 1 8-bitcounter/timer w auto-reload CKCON = 0x08; // Timer 1 uses the system clock/1 TH1 = 0xE6; // Timer 1 Equation17.1 BaudRate for 460800 & 24Mhz ////TL1 = 0xFF; // Low bytes of Timer 1 TR1 = 1; // Timer 1 on S0MODE = 0; // 8 bit UART with Variable Baud Rate RI0 = 1; // Recieve Flag (Clear by software) ES0 = 1; // Enable UART interrupts SCON0 |= 0x10; // Enable receive (REN0 is 1) ////PS0 = 1; // Set to high priority } void Oscillator_Init() // Initialize clock to 24 MHz { int i = 0; CLKMUL = 0x80; // Clk multiplier enabled for (i = 0; i < 20; i++); // Wait 5us for initialization CLKMUL |= 0xC0; // Initialize multiplier while ((CLKMUL & 0x20) == 0); CLKSEL = 0x02; // SYSCLK uses 4x Clk multipler/2 OSCICN = 0x83; // Internal oscillator/1 } void Port_IO_Init(void) { XBR1 = 0xC0; // Weak Pull Up Disabled and Crossbar enabled P1MDIN = 0xFF; P1MDOUT = ~0xE0; // Sets P1.5,6,7 as open drain P1 = 0xE0; // Logic high and high impedance if out.n=0 XBR0 = 0x07; } void Reset_Sources_Init() { int i = 0; VDM0CN = 0x80; for (i = 0; i < 350; i++); // Wait 100us for initialization ////RSTSRC = 0x84; }
