Has anyone ever seen an authoritative document on using debug functions in uVision3? It could be a powerful tool if I knew how to use it, but what little information I have come across is scattered across 2 hardcopy manuals, a bit more in the help file system, and smatterings in the Keil Knowledgebase. Here are clues, not documented anywhere, that I have discovered by trial and error: - If the last line of a .ini file containing function definitions does not end in a CR/LF, you get a "syntax error". - The "Breakpoint Set (BS), and "Go" (GO) commands may be executed from the command line, but not inside a function. - If you access program variables from the function, you must halt execution at a point in the program where they are all in scope before you load the function with an "include" command. Otherwise you get another "syntax error." - When you define and/or when you invoke a function, you must terminate its name with a pair of parentheses. When you "kill" the function, you must omit the parentheses. Otherwise, you get another one of those ubiquitous "syntax errors". - It could be that everything is a syntax error in this domain. The messages are that useful. :-} Perhaps if we all pool our insights, we will have a running start on a manual. ============================================================ Gary Lynch | To send mail, no$pam in domain name lynchg@no$pam.com | must be changed to stacoenergy.
Way back on Dec 5, 2005; I posted to this forum under the aforementioned subject line: > > Has anyone ever seen an authoritative document on using > debug functions in uVision3? It could be a powerful tool if > I knew how to use it, but what little information I have > come across is scattered across 2 hardcopy manuals, a bit > more in the help file system, and smatterings in the Keil > Knowledgebase. >
I issued a challenge to all users to share what they had figured out around this topic, hoping our combined knowledge could be compiled into our own, home-grown user's manual. From the deafening silence, I concluded there wasn't much knowledge to go around.
On Friday, August 04, 2006 9:46 AM; I received a message from fellow forum denizen, Petter Gran-Jansen: > > Hello Gary. > > My name is Petter Gran-Jansen and working with uVision3, > ARM, Agsi, signals and functions. > > I have read your Forum mail "User defined functions > uVision3" dated 12/6/05. > > I agree. ... >
This was followed, approximately 2-1/2 hours later, by a message from Reinhard Keil: > > Hello Petter, > > well it is sometimes good to tell others your frustration. I > also agree that documentation can be improved a lot and we > are actually hiring in the moment people for doing this. >
I would like to extend a warm "Danke schön" to Herr Keil for taking notice, and look forward to seeing what he comes up with.
For Petter and fellow suffers of this documentation dearth, I have not been sitting on my hands in the 9 months since my original rant, and have had some success solving problems with user-defined functions, which I share with you all.
You are going to have to read it piecemeal as the server prohibits me from saying all I want to in one breath. If you are reading this with Internet Explorer and the preformatted sections have white bands running across the width, try re-sizing the window.
This info came from:
Getting Started User's Guide +--Introduction +--Creating Applications +--Testing Programs | +--Tips and Tricks # | | +--Command Input from File # | | +--Write Debug Output to a File +--Sample Programs +--Using On-Chip Peripherals +--RTX51 Tiny Real-Time Operating Systems uVision (R) IDE User's Guide +--uVision3 Overview +--User Interface +--Creating Applications +--Utilities +--Debugging | +--Debug Windows and Dialogs # | | +--Output Window-Command | +--Tips and Tricks | | +--Command Input from File | | +--Write Debug Output to a File +--Debug Commands # | +--INCLUDE # | +--KILL # | +--LOG +--Debug Functions # | +--Creating Functions # | +--Invoking Functions # | +--Predefined Functions # | +--User Functions # | +--Differences Between uVision3 and C +--Simulation +--Flash Programming +--Dialogs +--Example Programs +--Command Line +--Appendix
User-defined functions are a powerful debugging tool, but they are also wretchedly difficult to master. The following guidelines aim to make this process easier.
[continued in part 2]
