using RTX51 Tiny
I am trying to communicate using UART port 0 on an 8051 platform (MSC1210Y5). The routine is interrupt driven, however, I use the os_wait function in the RTX51 Tiny kernel to aid the process. I have a 16byte circular buffer which faciliates transmission/reception of data.
This is my first time building an RTX51 driven code using uVision 3.
My problem is that I cannot display data using an MSC1210 demo board, with the code I developed. I ran the debugger and the code seems to work fine, however when I download it to the board, it doesn't seem to work.
I had previously developed a purely interrupt driven serial port routine and it worked. So I know the UART on the demo board is functional.
Any hints, suggestions...
