the number of tasks
I am debugging some source code with Keil uv3 IDE. We are using ARTX for ARM. My question is how can I find out the number of tasks managed by the RTOS?
  • Jian,
    I don't use the Arm compiler, so what follows is unlikely to work for you, however here we go:
    - the debugger can tell you right away how many tasks are running, plus much more information. It should be part of the "peripherals" menu.
    - if you want your own program to know how many tasks are running, a good place to start looking is os_active_TCB[].
    I imagine that a piece of code like:
        #include "blah...\AR166\SRC\Kernel\AR166_Config.h"
        #include "blah...\AR166\SRC\Kernel\AR_C_Interface.h"
        unsigned int NumberOfRunningTasks = 0;
        for (i=os_maxtaskrun; i--;)
            if (os_active_TCB[i]!=PNULL)
                NumberOfRunningTasks++;
    Should get you near what you want to do.
    $.02
    Steph-
  • Jian,
    $.02
    Steph-
