Hallo, the function Test is calling the functions func1 and func2 via a function pointer. Looking the *.map file, the addresses of func1 and func2 are located on even address, but the function pointer always has the correct address + 1. In my example: pf1:00101929 pf2:0010192d In *.map 00101928H CODE --- func1?T 0010192CH CODE --- func2?T Can anybody explain me this difference? Thanks Eugen
void func1(void) { } void func2(void) { } void Test(void) { char Buf[100]; void (*pf1)(void); void (*pf2)(void); pf1 = func1; pf2 = func2; sprintf(Buf, "pf1:%08p pf2:%08p", pf1, pf2); //Result:pf1:00101929 pf2:0010192d pf1(); pf2(); }
This is because you are working in Thumb mode. The bit 0 of a function pointer encodes if the function is executed in ARM or in Thumb mode. When bit 0 = 1 Thumb mode is selected. Reinhard
