Need a clarification. I want to define two poiners. One pointing to an area in XRAM and the other within CODE memory. I further want both of these pointers to be stored in XRAM. unsigned char xdata *xram_pointer; unsigned char code *code_pointer; This defines the pointers. But, how do I get them to be stored in XRAM? As I understand it, this is how it is done: unsigned char xdata * xdata xram_pointer; unsigned char code * xdata code_pointer; Here the "xdata" next to the pointer name specifies that the pointer be stored in XRAM memory. Is this correct? Thanks.
Yes that's correct. Lex
Thanks.
A couple of ways to help remember how the qualifers work: 1) Think of them as left-associative. The qualifiers modify the thing to their left. If there is nothing to their left, then they'll modify the thing to their right. 2) For pointer declarations, imagine a vertical line drawn through the *. Everything to the left of that line modifies the thing pointed at. Everything to the right of the line modifies the pointer itself. const int x; // constant integer int const x; // also a constant integer int * const x; // const pointer to variable int int const * x; // variable pointer to const int int const * const x; // const pointer and const int const int * const x; // also const pointer and const int const int const * x; // both consts apply to the int, not the *
