How to input ASCII values coming from serial. E.g if 8-bit ASCII code '80' of alphabet P, or 8-bit ASCII code '49' of digit 1 is recieved at serial port, how do I input this ASCII.
"how do I input this ASCII?"
char received_character; received_character = SBUF;
thanks.. But I want to ask one more thing... When I recieve 49, do I recieve 1 or the ASCII 49. I mean to say that if I want to compare the value recieved how can I do that,.. char recieved_char; recieved_char='SBUF'; if(recieved_char==49) { . . } "OR" char recieved_char; recieved_char = SBUF; if(recieved_char==1) { . . } OR char recieved_char; recieved_char = SBUF; if(recieved_char=='1') { . . }
"When I recieve 49, do I recieve 1 or the ASCII 49." Computers store numbers in binary. The UART receives data in binary. It is just a representational issue. 00110001 binary equals 49 decimal equals 31 hex equals 61 octal equals 1 ASCII etc Maybe you should read an introductory text of some sort. Alternatively, as I understand that reading is unfashionable these days, you could experiment using the debugger.
What is a debugger and how is it used?
Stefan said: "Maybe you should read an introductory text of some sort. Alternatively, as I understand that reading is unfashionable these days, you could experiment using the debugger." Fatima replied: "What is a debugger and how is it used?" Oh well, it looks like you're stuck with just doing some reading, then! :-0 I suggest that you start by reading the uVision Getting Started Guide - and working through the example Projects in it
