HELLO I DON'T FIND THE API OF KEIL FOR AD7730 WHERE I COULD FIND THE API? IF YOU ANY INFORMATION ABOUT THIS, YOU COULD SEND mj.gomez@eupla.unizar.es THANKS
Hi Try http://www.analog.com/en/content/0,2886,760%255F788%255F5450,00.html and get the ad7710xxx.doc code examples, there are two. Have you used sigma-delta converters before? If not, the serial port may be the small part of your job. I know at least one consultant in the database who has designed a circuit with this part before.
