Problems with ULINK USB-JTAG Adapter
Hello! The problem is when i tryed to flash download or enter i get message "Device cannot enter bypass mode. Connection to target missing or incorrect". I cant find a reason why and when it happens. For about 3 mounth it works good.
1)Can i test my ULINK for capacity for work? 2)I find some connectors on printed circuit board of ULINK with RxD and TxD marks.What is destination of it?
  • Hi! I'm not big expert, but ULINK give me always a lot of problems, at least version uVision 2 (4.27).
    I get your same problem with the CPU external watchdog enabled.
    The only test I know for USB-JTAG is from "OCDS Driver Settings" (from "Options for Target" tab dialog), where you can read ULINK serial number, version and so on. When I loose the communication with JTAG I'm not able to read the serial number anymore.
    I have seen that version 5.05 have a completely new driver for ULINK, but I have not still tested it.
    Good luck !
    Good luck !
