Model large - command line option
hello all,
In keil 8bit compiler i am unable to find a command line option which will specify the starting address & the size of XRAM.
Can anyone help me out by giving the control directive to specify the size & starting address of XRAM?
This is needed because i am compiling the program with model large.
Thanks in advance,
Chris
  • "In keil 8bit compiler i am unable to find a command line option which will specify the starting address & the size of XRAM."
    That's because it's a Linker option - not a compiler option.
    You need to look in the Linker manual.
    Note that uVision shows you the command line options that it uses - so you could just set up your requirements in uVision, and use the resulting options...
