Hi all friends. I use LPC935 for my project and the powersupply for this type is 3.3V. I want to communicate with GSM phone trough UART at 115200b/s with internal RC oscillator @7.373Mhz.The BRGR0 and BRGR1 values are set for 115200b/s(BRGR0=0x30 and BRGR1=0x00).LPC935 recieves the data correctly trough the RxD-pin(pin 1.1)but when sending the data to the phone, the phone doesnot respond to it. When same data is sent trough a datacable from the PC, the phone responds correctly. My question is whether the signal of the TxD of the LPC935 is not high enough to be able to communicate with the GSM. Do i need to put a pull-up or pull-down resistor or do i have to do something else. Im stuck and really need yours help. Any help is very much appreciated Embedded
Are you using an RS232 tranceiver device?
"My question is whether the signal of the TxD of the LPC935 is not high enough to be able to communicate with the GSM" What does the Manual say? Beware: some GSM modules use "unusual" voltages like 4.2V - you really must read the manual carefully, and design accordingly.
When same data is sent trough a datacable from the PC, the phone responds correctly. So, the thing respond to RS232 levels My question is whether the signal of the TxD of the LPC935 is not high enough to be able to communicate with the GSM. Do i need to put a pull-up or pull-down resistor or do i have to do something else. Im stuck and really need yours help. CONFOUND IT, you need to "do something else" install a RS232 transciever!!!!!!!!. If you decide to post again under another name, you WILL get the same answer. Erik
Thank you for the reply. I use RS-232 tranciver only for the communication with the PC. As i could read the manual of the GSM the signal required for the communication is TTL which is around 5V, correct me if im wrong. So is there a way to convert 3.3 output of the LPC935 to 5V without using a transistor with a resistor? Best wishes
I use RS-232 tranciver only for the communication with the PC. As i could read the manual of the GSM the signal required for the communication is TTL which is around 5V, correct me if im wrong. So is there a way to convert 3.3 output of the LPC935 to 5V without using a transistor with a resistor? 74HCT vith Vcc = 5V is 3.3 in and 5V out. Erik
