Hi everybody I am working on ADuC7026 which posses 64k FLASH and 8k RAM. I would like to place 24000 samples of speech anywhere so that i can access it sample by sample or by block. I have used CONST and RAM but it isnt working with that. So is there any particular procedure to follow so that i can place it in FLASH or RAM. Because it is giving me an error like FLASH is full. /cygdrive/c/Cygnus/Arm-Tools/Bin/../lib/gcc-lib/arm-thumb-elf/3.3.1/../../../../arm-thumb-elf/bin/ld: region IntFLASH is full (speech.elf section .rodata) Kindly need an suggestion so that i can carry on. Thanks Hameed
"I would like to place 24000 samples of speech anywhere so that i can access it sample by sample or by block." Your question is not clear: 1. What size is each sample? 2. Are these samples fixed at compile time, or do you want to record speech at run-time?
