I wish to install a bootloader in a specific sector of the LPC2106. How can I place a section of code to start at a specific address? Thanks Rich
That'll be a job for the Linker/Locator
Yes, that is true. the question remains........
You'd do this by sending a CODE() directive to the linker. For instance, if you had a file named BAR.C with a function FOO() in it, you'd specify: CODE(?PR?FOO?BAR(0xXXXX)) where 0xXXXX is the memory address you want the function located at. There are some variations in the way the compiler might name the segments, but that's the general jist of it. If you want to do this in uVision, you'd go to Project->Options for Target and choose the BL51 locate tab and type something in the edit box next to the word "code." (ie. put ?PR?FOO?BAR(0xXXXX) there. For more information about how things are named and what you can do to locate program and data segments at different places, just look in the compiler and linker manuals.
Take a look at the SEGMENTS linker directive. http://www.keil.com/support/man/docs/la/la_segments.htm Jon
Thanks all for the help. Rich
I am having no luck getting this to work. I have added the line: LA IAP.OBJ SEGMENTS (?PR?Copy_RAM_Flash?(C:0x1E000)) to the User segments box in the LA locate tab. First, do I have to manually locate every function when I want an entire portion of C code located in a certain area? The above results in a linker error L110 cannot find segment error. Rich
I am loading: DATA (0x40000000-0x4000FFFF), CODE (0x1E000-0x1EF00), CONST (0x1C000-0x1D000)) into the User Class box in the locate tab. This works as expected. I have created a user class with this: #pragma userclass (code = IAP) // generates CODE_IAP class According to the MAP file this worked. Buuuut when I add this: CODE_IAP (0x5000-0x6000) to the user class window I get a syntax error. Rich
First, do I have to manually locate every function when I want an entire portion of C code located in a certain area? You may use wildcards in the segment specifications. For example, ?PR?*?MYFILE selects all program segments from the MYFILE source file. The above results in a linker error L110 cannot find segment error. Compile and link without using the SEGMENTS directive. Scan thru the MAP file for the segment name to use. You should only specify the physical address. The C: prefix which is required in the 8051 tools is not allowed in the ARM tools (since memory is von Neumann). Jon
According to the MAP file this worked. Buuuut when I add this: CODE_IAP (0x5000-0x6000) to the user class window I get a syntax error. What version of the ARM tools are you using? I tried this with the V2 stuff and everything works just fine. You can download the V2 eval software from http://www.keil.com/demo. Jon
Richard, The user class stuff is definetly better that using wildcards with segment names. I think you have just a minor problem and you have entered it on the wrong place. Reinhard
Reinhard, You are correct on both counts, the classes are the way to go and I had to workout the details: #pragma ..... plus class definition in LA Locate Thanks for the good support (Even now that I am on the "outside") Richard
I have this ALMOST working. I am writing a bootloader to update on-chip flash. I have the BL code located in an upper sector and it all works well except that the IAP calls result in a code fetch from sector 0 which has been erased. Although I was able to locate the BL code to an upper sector there is still a segment called ?PR?C?SDIV which remains. The pragma/User class method does not cover this segment. So I am back to trying to locate this segment manually and have had no luck so far. Rich
