asm endasm and src directive, combining C and ASM languages
I have a pretty big file that during it's performance, in a specific place of the code flow, I would like to wait for exactly 4 clock cycles.
The best way for me to do this, is using the empty line command (; // nop).
Unfortunately, this doesn't produce any ASM code line (why ? maybe it was optimized ?)
Next, I tried to add an the following lines:
#pragma asm
NOP;
NOP;
NOP;
NOP;
#pragma endasm
and have enabled the SRC directive for this particular file from the Keil uVision.
This works, but with one limitation: the whole file was translated into assembler file, not just these 4 lines, and this cause the debug operation to be much harder (when runing step-by-step, for example).
Is there a way to tell the complier to create an assembler code for this NOP section only ?
Can you think of any other (better) way to achive the required goal ?
Thanks,
Amit A.
