Serial port Communication PC and AT89C52 ( continuted )
Here was my plan to realize the communication between PC and AT89C52, Both of them are set to 2400 (baud rate), N, 8, 1.
1. I have shortened pin 2 and pin 3 of RS-232 attached to PC. When my pc was sending out DATA, at the same time it can receive this DATA. After doing this, I found my PC can correctly receive the DATA just sent out.
2. The following is my C51 code. After receiving the incoming data, I want to show that data by LED connected to P1 port.
I thought my C51 code should be wrong, but I really have no idea……Please help me….
Sincere Thanks in advance.
unsigned char ISRIN;
unsigned char ISROUT;
unsigned char SERIALISRIN;
void DELAY ();
void INI_SERIAL();
unsigned char RECE_SERIAL ();
void main ()
unsigned char DATD;
P1 = 0xff;
INI_SERIAL();
While(1) {
if (ISRIN ) {
ISRIN = 0;
DATD = RECE_SERIAL ();
void SERIAL_ISR ( ) interrupt 4 using 1 (
if ( TI ) {
TI = 0 ;
ISROUT = 1;
if ( RI ) {
RI = 0;
ISRIN = 1;
void INI_SERIAL() {
EA = 0;
T2CON = 0x34;
RCAP2L = 0x64;
RCAP2H = 0xff;
TL2 = 0x64;
TH2 = 0xff;
SCON= 0x50;
TI = 0;
RI = 0;
TR2 = 1;
ES= 1;
EA =1;
unsigned char RECE_SERIAL () {
unsigned char DAT;
P1 = SBUF;
DAT = P1;
DELAY ();
P1 = 0xff;
return DAT;
