XRAM and Memory Model
Hi everybody!
I'm using a uC ADuC842 (based in 8052 core). It has 2 KB of XRAM On-Chip.
I have a test program (C code) which do some operations with float numbers and send results to the serial port.
When I use this compiler configuration:
- Memory Model: small: variables in DATA
- Code ROM Size: Large: 64K program
I haven't any problem and compiled code runs perfectly in ADuC842.
When I change compiler configuration to:
- Memory Model: Large: variables in XDATA
- Check Boxes selected:
+ Use On-Chip ROM (0x0-0xF7FF)
+ Use On-Chip XRAM (0x-0x7FF)
I simulate compiled code with uVision and it runs perfecly (like before), but when I run compiled code in ADuC842 it doesn't work.
It seems that I have problems using XRAM, but I don't know where.
Sombody can help me?
Comment: I have researched along the Disscusion Forum and I have read that it's necessary use startup.a51 to initialize uC. I don't know how call that segment in my C code program. Can this solve my problem?
Thaks!!
