001B C200 E CLR ?search_fine?BIT 001D 120000 E LCALL search_fine I'm getting IMPROPER FIXE-UP at this assembly routine. How can I fix this problem ? function defined like following
bit search_fine(bit down_up)
Maybe this helps: http://www.keil.com/support/docs/2157.htm
