hi I am facing a problem in parameters retrieval. I call a function of assembly from C.I pass a struct pointer in the parameter.I am using the Small model. Parameter are stored at the fixed memory location which is ?functionname?BYTE how can i use this parameters in assembly. I want to initalize the DPTR with the function pointer passed in the parameter. if i use instruction mov DPL,R2 mov DPH,R1 then this is not working i also uses these instruction mov DPTR,?functioname?BYTE this generate a syntax error. Your kind help will be most appreciable. regards Farhan Arshad
