I have a project for which the overall level of optimisation is set to the maximum. However, for a few modules (e.g. ISRs) I tried to set an optimisation level below that of Common Block Subroutines. However, in the object code, there are common blocks thoughout. Is it possible to build a project with Common Block Subroutines optimisation for most of the code, but deselected for individual modules?
Can't you just select it in the individual file's properties? Or put all such files in a Group, and set it for the Group?
...or the Manual shows you how to select the optimisation level on a function-by-function basis: http://www.keil.com/support/man/docs/c51/c51_optimize.htm
Are you using the LX51 linker and Linker Code Packing? Jon
Andy: The optimisation level for the entire project is set at 11. I have tried reducing the optimisation level to 8 for a group, for individual files and I have tried putting
#pragma OPTIMIZE(8,SPEED)
Have you turned off linker code packing for a group? I would think that should do it. Jon
OPTIMIZE(8,SPEED) still performs common entry optimization. Did you try it with OPTIMIZE(7,SPEED)?
I cannot turn linker code packing off for a group. I have tried turning down optimisation to 7 for the specific file and this does seem to prevent common subroutines in the functions therein. Why does level 7 work when I would have expected level 8 to do the trick?
