hi all, I am using Proteus simulator and keil uvision2 to develop some graphic LCD library function.I am using the code from one of the sites to write pixel which is working fine. but reading is getting me problems.I am using LGM12864BS1R graphic LCD with AT89c51 microcontroller running at frequency 11.0592MHz.The read function is as follows. any help would be highly appreciated. U8 LcdDataRead () { LCD_DATA = 0xFF; /* set LCD_DATA port in input mode */ LCD_RW = 1; /* Read mode */ LCD_DI = 1; /* Data mode */ LCD_E = 1; /* strobe */ LcdDelay(1); LCD_E = 0; LcdDelay(1); return LCD_DATA; /* return the data read */ }
Hi, Sorry we can't help you. But you can help us we r using KS0108B based Graphical LCD.We have tried to display some data on it but all in vein.so can u please share your code for writing data on LCD display. thanks
