Hi everyone I'm having trouble reading the right values from the uart using a serial port logger. I'm using the cygnal C8051F124 uc and I send in four bytes a float variable by the UART0 To convert the flot variable in 4 bytes I have the following code: union { float floater; unsigned long int longinter; unsigned char string[4]; unsigned int interger[2]; }float_char; To convert I use: float_char.floater=0.43567; sendbuff[0]=float_char.string[0]; sendbuff[1]=float_char.string[1]; sendbuff[2]=float_char.string[2]; sendbuff[3]=float_char.string[3]; Then If I sent the same value stored in sendbuff[x] everytime I send the data by the UART0 I get the exact value without errors. That means maybe the conversion from float to 4 bytes is incorrect or maybe cause some problems. I think the UART tranmission is correct because if I dont change the value in the sendbuff[i] variables I obtained in the pc the values that I want. Please give me suggestions Thanks
