I'm trying to fill an array with a rotating counts then add the all up each time the sub is called. When I simulate this code I never see the i++ index. I guess keil supports i++ by itself.
i++; if(i == 10){i == 0;} array[i] = data; data = 0; for (a = 0; a < 10 ; a++) {data = data + array[i];}
It's hard to figure things out since you didn't specify any variable types.
i++;
unsigned int func (unsigned char data) { #define ARRAY_SIZE 10 static unsigned char ndx = 0; static unsigned char array [ARRAY_SIZE] = { 0, }; static unsigned int array_ttl; if (++i >= ARRAY_SIZE) i = 0; array_ttl -= array[ndx]; // remove oldest data array_ttl += data; // add newest data array[ndx] = data; // add newest data to array return (array_ttl); // return total or return (array_ttl/ARRAY_SIZE); // return average }
