Hi! Is it possible to rename projects? How do I do this?
True - but you may still want to change the Target name(s) if you've "renamed" the Project.
'Name of Executable' on the 'Output' tab of the Project options! No, because that's actually the 'Output' tab of the target options. A project can have multiple targets, each with a different executable name.
and the 'Name of Executable' on the 'Output' tab of the Project options!
A uV2 project really doesn't have any name to be changed in the first place. Well, none except for the filename of the .uv2 and .opt files themselves. Rename those files, and you've renamed the project.
