hi friends iam working on cygnal mcus silabs, i need c programme of serial communication pc to controller.ialready used hyperterminal iam getting results but iwant to make my own menu driven software in that iwannna call the serial programme as fucnction kindly any is having c programme of serial communication send me immediately regards kris
Just look in the downloads section of this very site!
hi neil thanks for your advice, actually i need c programme that will run on TC (TURBO C)will initialise 1:1 connections of rs232 to uart of microcontroller, that one ican use as function in my programme if u have then please send me a copy regards kris k
You mean you want the PC code? In that case, you need to ask on a PC forum! Try putting a few keywords like "Turbo-C" and "Serial" into your favourite internet search engine...
Kris k, you should get together with John e. You both seem to have the same level of knowledge and be working on the same project - I think you could help each other out a lot. Stefan
