OPTIMISING CODE
HI
all iam working on cygnal mcus,we have limited keil programme space of 1000bytes
now my programme is yet to cross the limit .
how to reduce the code size , if any one knows please put a reply to me
regards
john e
  • What optimisation setting are you using for the Compiler and/or Linker?
    Have you read the Appendix "Writing Optimum Code" in the Manual?
    Other things to look at:
    Remember that accessing XDATA is both slowest and uses most code; PDATA is quicker, and uses less code; DATA is quickest, and uses least code.
    Loops counting down to zero are more efficient, as the compiler can use the DJNZ instruction.
    Remember that printf uses loads of code!
    Avoid int and anything larger; if you haven't already, try disabling ANSI Integer Promotion.
    Use Register Banks for your ISRs.
    Use Keil's bit extension for Boolean flags.
