How to insert Assembly code into C code
I have got this code which insert Assembly code into C code. How can the parameter of the function,tx_buffer be passed into the assembly? Also what is the value of R7 in the first line? And how can it return a unsigned char?
unsigned char DriverLoadHeader(unsigned char tx_buffer)
#pragma asm
	MOV A, R7
	MOV R1, A
	INC R1
	MOV R0,#HEADER_SIZE
;Reset to TX FIFO
	MOV A, #10
	MOV DPTR, #SCR2
	MOVX @DPTR, A
	MOV DPTR, #TX_FIFO
LOAD_LOOP:
	MOV A, @R1
	MOVX @DPTR, A
	INC R1
	DJNZ R0,LOAD_LOOP
#pragma endasm
	return 1;
