I want to use ISD51 on Dallas DS5001FP, can I do that? I already try to use the ISD51 (generic 8052) example from Keil. There is no result and I still can't get connected. What I do is : DS5001 PC TX RX RX TX GND GND EEPROM 8Kb connected with the Byte wide bus of DS5001.
do you have an RS232 transceiver (eg, MAX232) between PC and DS5001?
You are entered into the contest for the most descriptive post heading. Erik
