Hello all,
I am using STM32L053 Nucleo board. I have C code for LCD interfacing with STM board. When I am compiling my program it gives error in .axf file "Can not find argument Reset Handler". .axf file location is in objects/LCD_2.axf & that file is also not generated. So is there any help to solve this issue..
As the error points out, you would have to put "Reset Handler" in startup file.
Genereally, it is written liek below:
Reset_Handler PROC EXPORT Reset_Handler [WEAK] IMPORT __main LDR R0, =__main BX R0 ENDP
I would recommend to play with couple of examples from Pack Installer to see the process
