Hi, Is there an easy way to inhibit the link/locator from placing code at a specific address? I know could manually locate a 'dummy' module containing a number of __nop__() calls to the address range that I want to 'mask', but this dosn't seem a very tidy solution. Anyone have any better solutions? Thanks David
char code dummy[size] _at_ address; should do it. Stefan
You can also specify multiple code areas that the linker CAN use. You can simply exclude the areas that you don't want the linker to use. For example: Code(0x0000-0x7FFF,0xA000-0xAFFF) excludes 0x8000-0x9FFF and 0xB000-0xFFFF. If you use the LX51 linker, there is a RESERVE directive that reserves memory areas. Jon
