Hello, When I use the uVision 2 (v. 2.31) under WinXP - Home Edition, then from time to time some files cannot be compiled by the C51 compiler (v. 7.01). The OS is then telling me that the C51/CX51 compiler has caused an error and that the program (the compiler, not uVision2) has to be ended. Mostly, it's related to a macro 'ASSERT()' with the following definition:
#define ASSERT(expr) if (expr) { ; } else { printf("Assert failed: " #expr " (file %s line %d)\n", __FILE__, (int) __LINE__ ); while (1); }
Hello, The problem does not exist anymore with the compiler version 7.02b Rgds, Geert
I'll try with version 7.02b and let you know asap. Thanks anyhow for your response on this message. Rgds, Geert
Does the problem still exist in V7.02?
