i am stuck at problem, i tried to crate 3, out of which 2 tasks for getting i/p from user. each of two task stores 1 int to reg and third task calculate addition of two and display output at serial port.. problem: how to access register and use them? ..... NEED HELP!! if any one could tell me where to find some material on this stuff... i have already read REGFILE Compiler and linker directive ... but could'n get how to use it?
Why should your tasks put data into registers, and expect a different task to pick up that data from a register?
What is wrong with using normal variables?
Just that it isn't enough to have variables - there must be some form of handshake logic so the consumer (the task that adds the values) knows that the two producers have produced any data.
And the two producers should be able to know if the consumer is keeping up.
An interesting thing here - you haven't even told what operating system you have using for creating your three tasks. Or have you accidentally used the word "task" when talking about normal functions? So your program is actually sequential:
get_input_1(); get_input_2(); compute_sum_of_inputs();
ohhh.. sorry .. i am using RTX51 Tiny RTOS.. all this is for understanding purpose.. i want to know is there way to access registers of processor with tiny.. and how rtos share its resources among various concurrent tasks....
It doesn't matter if you use any Tiny RTOS or not - your ability to access any registers on the processor is the same anyway. The 8051 does not contain any memory protection functionality that blocks the program from touching whatever it wants to touch.
But you still need to consider how to handle the natural handshake between two producers and one consumer, so the consumer only produces a result when it has valid input data from both producers. I think you should look into the producer/consumer model and the general function of thread synchronization before you start to read the documentation for Tiny RTOS.
