Hello
I have been using keil's uVision for a while and i was pretty satisfied. Until one day totally unexpectedly i received the following error:
Build target 'Target 1' compiling Blinky.c... C51 COMPILER V8.08 - SN: K1DEC-L281B9 COPYRIGHT KEIL ELEKTRONIK GmbH 1987 - 2007 C51 FATAL-ERROR - ACTION: PARSING SOURCE-FILE ERROR: PREPROCESSOR: MACROS TOO NESTED C51 TERMINATED. Target not created
I do not use any macros , or complex defines etc. I receive this even while trying to compile a simple "Blinky" app. I haven't messed with Linker-Compiler-Assembler flags-settings. The weird thing also is that this error , for the same code ,doesn't appear no Silab's IDE. I know all this seem peculiar but if this problem has occured to anyone else and solved it i would be very happy if he shared the solution with me.
Thank you P.S New Embedded programming..
