Hello
I am new to embedded programming and i have been trying to transfer a binary file and save it to flash memory using uart. The problem is that i do not know when to stop reading bytes from uart. That is because in my project the files do not have standard size , nor have a special char in the end. Is there any technique for this to be done. I am using keil compiler and a beautifully "datasheeted" c8051f320. The uart ISR for reading the file is the bellow:
INTERRUPT(Uart_Isr, INTERRUPT_UART0) { if(RI0 == 1 ){ LED = !LED; //Blink LED for each input RI0 = 0; //Reset the uart read flag byte = SBUF0; //Store byte read flashBuffer[buffer_counter] = byte; //save it to a FLASH buffer buffer_counter++; if(byte == 4){ //If End Of Transmition fileTransfered = 1; REN0 = 0; //Disable RX } } }
I also used a c script to write 0x4 (End of transmition byte or EOT) in the end of the files to be downloaded(weird but worked if the file had only char data).
Thank you in advance
P.S some more complex expressions dont seem to work , like flashBuffer[buffer_counter+] = SBUF0; Meaning that i get my code compiled but the program doesnt work
The problem is that i do not know when to stop reading bytes from uart. That is because in my project the files do not have standard size , nor have a special char in the end. Is there any technique for this to be done. (re)start a timer in the UART ISR when it times out you are done. Make the time long there may be pauses in the transmission.
This is a kludge, the correct way is to make the EOR detectable.
Thank you for the quick reply. That is indeed a nice solution. What do you mean by saying to make EOR detectable? Also(that is a bit off topic) my project is to run code to an mCU downloaded from uart using a binary file. Is there a standard technique for that? I have read about code banking and bootstrapping but i only see complicated stuff. I just want to do a JUMP to the address where the file is saved and continue running code from there.
Furthermore , i managed to use RTX tiny from keil. I figured that an rtos would be usefull for such a project. Is that correct?
"Is that correct?"
For what you've described so far, it's probably more trouble than it's worth!
... when it is REALLY needed and the processor has the needed power.
a RTOS should not be an automatic decision, at least not when working with the '51.
So far so good , i managed to download a binary file using the way described above but my final goal is to get my mCU to run the downloaded binary file. After a lot of googling , and manual reading i haven't quite figured out how this is possible. I cannot just jump to a certain flash memory address nor can i use something like exec() from the rtos libraries (that is also a reason why i tried to use an rtos on my project). Is there any standard way to do this , do i have to use the rtos , can flash be used for such reasons or do i have to write extra code to retrieve code lines from flash and transfer them to code mem and then execute? Thanks in advance
P.S I didn't post this on a new thread because i re-mentioned the problem above.
is this a separate routine or are you trying to make a bootloadeer?
GET RID OF THE RTOS
The concept is to download and execute using uart a fully operative binary file and execute it on the mCu. This binary file is not a part of a program or function, this a file that if you download on a 'clean' 8051 would actually do something. In my project i want to transfer an executable file , stop the one that is running and run the transfered from uart one. I do not know how boot loader would be usefull for such operation.
What you are attempting is called "In-Application Programming" or "IAP" for short.
The fundamental problem with this on the 8051 architecture is that it has no means to write to the CODE space - so it is impossible without additional "tricks"...
You need to check the specific chip documentation carefully to see if it does provide any such "tricks"...
I have read this somewhere else too. I have also read some tricks like memory mapping but i haven't tried anything yet. So far the last two days i managed to write a program to download files to flash from uart. Anyways, if you happen to know any good 'tricks' for a c8051f320 from silabs i would be really happy if you shared them. Otherwise thank you very much for all the rest advice :)
Because the Flash is internal, there are no "tricks" that you can do yourself - you are totally reliant on what the manufacturer provides...
The F3xx have a sfr bit that makes xdata writes go to flash
The OP is actually talking of a bootloader which is possible with all SILabs chips (that I know of)
Searching again in silab's application notes page (www.silabs.com/.../ApplicationNotes.aspx) , i found one called "AN112 UART In-Application Code Loading Examples" that is an app similar to what i'm trying to do. I think this coding example should help me a lot understanding how iap on C8051Fxxx works. Thank you all for the replies.
