why can't the Loop states and multi-dimensions arrays run?
1. In my programme,there are some loop states such as the following:
int x,x1,x2;
x1=1;x2=100;
for(x=x1;x<=x2;x++)
y=k*x+b;
Pixel(x, y, Mode);
But in fact,the loop is executed only once,then run the wrong code and the code after the loop is never executed.can you give me some advices?
2.In my programme, there is a multi-dimension array like this--
unsigned char code HZTable[2][16]={....};
But the operation to the array always goes wrong.how can I resolve the problem?
thanks
Liu ***
huihl@163.com
