syntax Error in Peripheral Dialog Parameter LIne
hello,
about vu2 SDK.
firstly, I finished my own SPeriDLL.dll within MS VC++6.0,then I pushed the key F5 to launch the vu2.but in the vu2 ,when I pushed the DEBUG key to start debug ,the dialog with the message "揝yntax Error in Peripheral Dialog Parameter LIne? occured , my own SPeriDLL submenu was not added , the original submenus were vanished and at last the vu2 died.
actually,In my SPeriDLL,no SFRs or no VTREGS are defined.It is just a simply framework.
can you give some advices?
how can I get a correct SPeriDLL framework in which I can add my customized hardware ports?
thanks and best regards
