Memory expansion info and KEIL support
I have to improve a system memory capability
with the minimum IO usage possible. I am thinking to use I2C memory device which spends 2 I/O pins. There's also SPI devices which need 4 I/O pins. It will be very usefull if anyone could help with the following information:
1) Some I2C and SPI available vendors. Some vendors URL will be very usefull.
2) Does KEIL have I2C and/or SPI facility support ? Do I have to implement whole potocol by hand ? Does anyone have any example code using such memories ?
3) How can I connect I2C and SPI device to the AT89S8252 IO pins ? Which pins can I use ? Any pin ?
4) What is the difference between SPI and I2C memory devices ? Which one is cheaper ? What are the good and bad features of them ?
Any information on any of these topics will be very appreciated.
Thanks a lot,
Regards,
Andre
