Hi, I need a 1 Megabyte or more (FLASH or EEPROM) memory with I2C or SPI interface. Does anyone can help me ? I have searched a lot on the Internet at main sites but I couldn't find it. Regards, Andre
I doubt you will find it in serial, but ST micro has up to 4M byte in parallel flash. Erik
PS it's cheap <$3 for 2Mb Erik
http://www.atmel.com/atmel/products/prod46.htm http://us.st.com/stonline/prodpres/memory/flash/sp_hd.htm
That's what I was looking for. Thanks a lot, Andre
http://www.sst.com also provides 25 series serial flash from 64KB to 2MB with SPI interface, but 3V parts only, no 5V parts.
You can use the M24512 (64kByte) with I2C-bus from ST. To increase the number of components it is a good idea to use the MAX4562 video switch! (Maxim app.note APP 955). With one MAX4562 it you can address up to 24 components. It is possible to address 4 MAX4562 switches. Result: 4x 24x 64kByte = 6MByte (= 48MBit)I2C fast (400kHz) addresseble EEPROM. Expensive ($280.-), but IT WORKS!
