I want to use C mixed with assembler. I wrote the following experimental program: void main(void){ char i,a[20]; for(i=0;i<20;i++)a[i]=i; #pragma ASM MOV A,#29H MOV R2,A ..etc.. #pragma ENDASM } When building this program together with Startup.a51, the following linker warning appears WARNING L1: UNRESOLVED EXTERNAL SYMBOL SYMBOL: ?C_START MODULE: .\Startup.obj (?C_STARTUP) WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: ?C_START MODULE: .\Startup.obj (?C_STARTUP) ADDRESS: 2029H After adding some other statements the program became this: #include <stdio.h> #include "setUpSerPort.h" void main(void){ char i,a[20]; for(i=0;i<20;i++)a[i]=i; setUpSerialPort(); printf("program running"); #pragma ASM MOV A,#29H MOV R2,A ..etc.. #pragma ENDASM } file setUpSerialPort.h contains #ifndef setUpSerPort_h #define setUpSerPort_h void setUpSerialPort(); #endif file setUpSerialPort. c contains void setUpSerialPort(void){ #ifndef MONITOR51 SCON = 0x50; TMOD = 0x20; TH1 = 221; TR1 = 1; TI = 1; #endif } When building this project thelinker warnings have gone! But why?? With regards.
When you compile a C file, the C compiler includes external references to the startup code. This way, you don't have to manually include the startup code if you have a simple C program like:
void main (void) { while (1); }
