Weird Linker Error (L6218E: Undefined symbol)
Hello Everybody,
I am trying to build a firmware which is using two functions from the Keil SAM-ESV7_SFP 2.4.5 library. The compile process is okay, but I can not get the linking going.
*** Using Compiler 'V5.06 update 6 (build 750)', folder: 'C:\Keil_v5\ARM\ARMCC\Bin'
Build target 'Target'
compiling afe_dma.c...
linking...
.\Objects\Target.axf: Error: L6218E: Undefined symbol Afe_SendData(AfeDma*, AfeCmd*) (referred from receiver.o).
.\Objects\Target.axf: Error: L6218E: Undefined symbol Afe_ConfigureDma(AfeDma*, Afec*, unsigned char, _Xdmad*) (referred from receiver.o).
Not enough information to list image symbols.
Not enough information to list load addresses in the image map.
Finished: 2 information, 0 warning and 2 error messages.
".\Objects\Target.axf" - 2 Error(s), 0 Warning(s).
Target not created.
Build Time Elapsed:  00:00:01
Now the weird part: The two functions Afe_SendData and Afe_ConfigureDma is defined in the afe_dma.c which gets compiled succesfully. The afe_dma.o gets generated in the Objects subfolder.
I have tried to remove the afe_dma.c from the sources and I got the same exact error as I should, but when I put it back, the file gets compiled, but the error stays.
I have tried to clean and rebuild the project several times. There are no weird characters in the paths of the project, Keil tools or the include paths.
Why the linker does not recognize the the compiled afe_dma.o? Is there a way to explicitly tell the linker to link a specific *.o file?
Thank you very much.
