Hi, all I encounter a problem that as follow: I create two projects. the one will be compiled to a library, and the other will use the library. But, an error throw out when linking in the second project. as follow: linking... .\Objects\output.sct(7): error: L6236E: No section matches selector - no section to be FIRST/LAST. Not enough information to list image symbols. Not enough information to list load addresses in the image map. Finished: 2 information, 0 warning and 1 error messages. ".\Objects\output.axf" - 1 Error(s), 0 Warning(s). Target not created. my environment is: Windows7 MDK 5.25 can somebody give some clue? thanks Best regards.
oh, sorry, how to input line feed/break ?
my environment is: Windows7 + MDK 5.25
can somebody give me some clue? Best regards.
See: www.keil.com/.../
Thanks for your patiently reply. and do you know how to solve the question"no section to be FIRST/LAST"error, when startup file be in library"?
Not off hand, but my first step would be to put the message into the search box here. And into an internet search ...
Don't put the startup file in a library.
