I have questions as following, I think that there has no address information in the BIN file, but from my testing, there has different BIN generated with different address
Flow 1. "Options for target" > "Target", set IROM1 to 0x8003000 then generate BIN1 file Flow 2. "Options for target" > "Target", set IROM1 to 0x8005000 then generate BIN2 file
After doing that, I use software to compare two files, I found that the files are not the same.
So, my question is, 1. Any document or material to describe it about this topic? 2. If I flash BIN1 file into 0x8005000 and using boot loader to jump it and correct setting interrupt vector table in 0x8005000, does the firmware can work correctly?
Thank you so much.
That is correct - it is just a byte-for-byte representation of the data.
After doing that, I use software to compare two files, I found that the files are not the same."
Did you try repeating Flow 1 to see if it actually generates identical bin files each & every time?
Any absolute addresses in there are going to be different.
