I downloaded the latest SDK (2.5.0) for LPCXpresso54018M board from NXP for KEIL IDE.
I connect to the target via P1 (external debug probe) with ULINK2-ME Sieger probe. When I attempt to start a debug session for any examples from the SDK, KEIL IDE is always giving me the following error:
"ERROR FLASH DOWNLOAD FAIL"
The log from KEIL IDE shows:
Load "D: \\54S018M_SDK_2.5.0\\keyboard2mouse_bm\\debug\\keyboard2mouse_bm.out" No Algorithm found for: 00000000H - 0000A7BFH Erase skipped! Error: Flash Download failed - "Cortex-M4" Flash Load finished at 14:39:54
Please note I am attempting to debug from RAM (not flash) , the linker setting are set correctly (default setting from the SDK example) .
Please note the debug setting (default from SDK example) are also correct. They are as follow (jlink_sramx_debug.ini)
FUNC void setup(void) { SP = _RDWORD(0x00000000); /* Load the SP value from RAM vector table. */ PC = _RDWORD(0x00000004); /* Load the PC value from RAM vector table. */ _WDWORD(0xE000ED08, 0x00000000); /* Relocat the vector vable to RAM table. */ }
FUNC void OnResetExec(void){ exec("LOAD %L INCREMENTAL");
setup(); }
/* Load the image file into SRAMX*/ LOAD %L INCREMENTAL setup();
//g, main /* Run to main. */
Please note the probe work, the debug attempts on LPCXpresso5460x8 board with the same probe work w/o problem.Although it download into FLASH not RAM
A what??
And note the instructions for properly posting source code: http://www.keil.com/forum/tips.asp
I apologize for the improper formatting of the content from the .ini file. What is your question regarding my original post?
It looks like the debugger does not understand that you want to skip flash programming. Maybe some checkbox ("download to flash") should not be checked?
