Hi, I'm using LPC1768 controller keil v5.24.2.0. In the LPC1768 controller i put tcpip,http stack and some other application to it. While executing data memory reaches around 32700 it works well. But after that it gives an error".\Objects\IIOT Raw.axf: Error: L6406E: No space in execution regions with .ANY selector matching server.o(.data).". Before reach the error the memory limits are Program Size: Code=35844 RO-data=31472 RW-data=300 ZI-data=32348. But in a datasheet they given the data memory is 64K. How to use the full of that ram memory?</br></br>
Thanks & Regards, Prasanth.
If your linker script is wrong - indicating less SRAM that you physically have - you will get this.
Or, if this may happen if you actually need much more SRAM than you think.
I just add 200 bytes of short int variable it gives an error. If i didn't add that i doesn't gets an error. So 200 bytes are not much higher memory in remaining 32k. But i got an error.
