So I want to run a pre-build program and pass it a file name and the project name
The on-line help says that $P gives you the file path and at-sign gives you the project name (or at least hints at that).
So I try: python ..\Utl\BumpVersion.py $P @
$P works fine but at-sign (@) just echoes as at-sign (@). I've tried @@ and $@, no joy.
Ideas?
Both of those interpretations (the "gives you" one, and the "hints at" one) are wrong. You'll want to read the documentation on key sequence once more.
