Error while Preprocessing using ARMCC in RTRT TDP
Hi All,
I am working on TDP development for XMC-4700, while preprocessing the files i am getting the below issue:
"no source": Error: command-line:  #564: cannot open preprocessing output output file ".\Objects\*.d": No such file or directory
Below is the log for TDP build:
C:\Program Files (x86)\Rational\TestRealTime\bin\intel\win32\utags -sspgtags ..\Scripts\QualTest.ptu
Preprocessing PTU test script file...
C:\PROGRA~2\Rational\TESTRE~1\bin\intel\win32\attolpreproC "C:\RTRT\INPUTS\XMC\Sample scripts\Scripts\QualTest.ptu"      "cwinkeilxmc4700\TQual_non_instrumented.c"      -studio_log="C:\RTRT\INPUTS\XMC\Sample scripts\Working Folder\intermediates_files434474679.log" -STD_DEFINE="C:\PROGRA~2\Rational\TESTRE~1\targets\CWINKE~1\ana\atus_c.def" -RENAME=stubs_rename.opt -incl="C:\Keil_v5\ARM\ARMCC\include","cwinkeilxmc4700" -family=nominal -service=single_if_test_2 -NOSIMULATION -FAST
TestRT-I-STARTEXEC,  IBM(R) Rational(R) Test RealTime C Test Script Compiler 7.0.5.0.296.001
TestRT-I-COPYRIGHT,  (C) Copyright IBM Corp. 1992-2007 All Rights Reserved. All rights reserved.
cwinkeilxmc4700\TQual_non_instrumented.c: Preprocessing...
C:\Keil_v5\ARM\ARMCC\bin\armcc.exe -E --c99 -c --cpu Cortex-M4.fp -g -O0 --apcs=interwork --split_sections -I ./RTE/_TestRT_execution -I C:/Keil_v5/ARM/PACK/Infineon/XMC4000_DFP/2.7.1/Device/XMC4700_series/Include -I C:/Keil_v5/ARM/CMSIS/Include -I C:/Keil_v5/ARM/ARMCC/Bin -D__UVISION_VERSION="524" -DXMC4700_F144x2048 -o .\Objects\*.o --omf_browse .\Objects\*.crf  --depend .\Objects\*.d -I C:\PROGRA~2\Rational\TESTRE~1\targets\CWINKE~1\lib  "-IC:\Keil_v5\ARM\ARMCC\include" "-Icwinkeilxmc4700" "cwinkeilxmc4700\TQual_non_instrumented.c" -o "cwinkeilxmc4700\TQual_non_instrumented_aug.i"
C:\PROGRA~2\Rational\TESTRE~1\bin\intel\win32\attolcc1 "cwinkeilxmc4700\TQual_non_instrumented_aug.i" "cwinkeilxmc4700\TQual_non_instrumented_aug.c" atct.def  -exfile="cwinkeilxmc4700\TQual_non_instrumented.c" -noinstrdir="C:\PROGRA~2\Rational\TESTRE~1\targets\CWINKE~1" @stubs_rename.opt -proc=ret -block=logical -trace -mempro -perfpro   -studio_log="C:\RTRT\INPUTS\XMC\Sample scripts\Working Folder\intermediates_files434474679.log"
TestRT-W-ELMT_VIDE,  [C:\RTRT\INPUTS\XMC\Sample scripts\Scripts\QualTest.ptu:401] ELEMENT block  without any variables to edit
TestRT-W-TEST_VIDE,  [C:\RTRT\INPUTS\XMC\Sample scripts\Scripts\QualTest.ptu:403] No variables in the test 1
TestRT-W-NOMOPEDBL,  [C:\RTRT\INPUTS\XMC\Sample scripts\Scripts\QualTest.ptu:411] switch_case_test_1 service used more than once in the program
TestRT-I-ENDNOEWAR,  End of execution with 3 warning(s)
cwinkeilxmc4700\TQual_non_instrumented.c: 0 warnings, 1 error
cwinkeilxmc4700\TQual_non_instrumented_aug.c: Compiling...
C:\Keil_v5\ARM\ARMCC\bin\armcc.exe --c99 -c --cpu Cortex-M4.fp -g -O0 --apcs=interwork --split_sections -I ./RTE/_TestRT_execution -I C:/Keil_v5/ARM/PACK/Infineon/XMC4000_DFP/2.7.1/Device/XMC4700_series/Include -I C:/Keil_v5/ARM/CMSIS/Include -I C:/Keil_v5/ARM/ARMCC/Bin -D__UVISION_VERSION="524" -DXMC4700_F144x2048 -o .\Objects\*.o --omf_browse .\Objects\*.crf  --depend .\Objects\*.d   "-IC:\Keil_v5\ARM\ARMCC\include" "-Icwinkeilxmc4700" "cwinkeilxmc4700\TQual_non_instrumented_aug.c" -o "cwinkeilxmc4700\TQual_non_instrumented.o"
TestRT attolcc1 - INFO: No branches of requested coverage types can be found in file TQUAL_NON_INSTRUMENTED_AUG.I; no FDC generated
TestRT attolcc1 - INFO: No observable routine can be found in file TQUAL_NON_INSTRUMENTED_AUG.I; no TSF generated
cwinkeilxmc4700\TQual_non_instrumented_aug.c: 0 warnings, 1 error
status 1
Failed.
