STM32L072 Jumping to embedded bootloader from application code
MCU version 20KB RAM, 128 KB FLASH category 5. I tried solutions on the web available for different STM32 MCU with no success. BOOT0 pin is fixed to GND in my custom PCB.
My final code flow is like below:
1)Reset Handler
2)System init MSI as a system clock, reset all other clock settings and does something like below
SCB -> VTOR = FLASH_BASE | VECT_TAB_OFFSET; /* Vector table relocation in Internal Flash*/
3) Main Function
int main(){
HAL_RCC_DeInit();
Systick -> CTRL = 0;
Systick -> LOAD =0;
Systick -> VAL =0;
__disable_irq();
HAL_FLASH_Unlock();
void (*foo)(void) = 0x00000004;
__HAL_SYSCFG_REMAPMEMORY_SYSTEMFLASH();
SCB -> VTOR = 0;
__set_MSP(0x20005000);
foo();
while(1);
When i debug, code jumps to the location 0x00000004 but after some instructions device jumps again to reset handler.
Can you correct me to make embedded USBDFU bootloader work ?
Thanks in advance,
  • >>I tried solutions on the web
    Mixing up random ideas you copy and paste is not programming. Read the manuals and understand what you are doing.
    You must enable the SYSCFG clock before you can remap memory
    You should not __disable_irq(), no one enables it again. Turn OFF the interrupts in ALL the peripherals where you have enabled them.
    Four is NOT executable code, it contains a 32-bit data word describing where the code is, you should read the word.
    The value read needs to occur AFTER the remapping for the ROM data to be at zero
    I don't have an L072 to hand but this is a more cogent expression of what you need
    #define ROMBASE 0x1FF00000
    typedef void (*pFunction)(void);
    pFunction romboot = (pFunction) *((uint32_t *)(ROMBASE + 4)); // The content
    __HAL_RCC_SYSCFG_CLK_ENABLE();
    SCB->VTOR = ROMBASE;
    __set_MSP(0x20005000); // Arguably *((uint32_t *)(ROMBASE + 0))
    romboot();
    romboot();
