I am working on STM32L432KB with Keil uVesion5 and need to write its internal flash using IAP method. For that I use below API: HAL_FLASH_Program (uint32_t TypeProgram, uint32_t Address, uint64_t Data)
The last argument(data) of the API accepts data of type uint64_t. Data to be written in flash in stored in and array of type uint8_t.
While developing logic for the same, I am facing 2 issues.
1. Data is stored in uint8_t buf[500] and I want to copy its 8 consecutive bytes in uint64_t data variable. The code for the same is:
uint8_t buf[500] = {1,2,3,4,5,6,7,8,9,0}; uint64_t data, *ptr; ptr = (uint64_t*)&buf[0]; data = *ptr;
Here, when control reaches to the line data = *ptr;, it stuck there and never execute next line (the next line not shown here).
Can you guide me why control stuck there ?
2. Instead of typecasting the data into uint64_t, when I try typecasting it in uint16_t or uint32_t, problem discussed in point 1 is solved. Mean the controller can now process data = *ptr line (where ptr is of type uint16_t or uint32_t) But here, I am facing issues of endianness. See code below for more understanding:
uint8_t buf[500] = {1,2,3,4,5,6,7,8,9,0}; uint16_t data, *ptr; ptr = (uint16_t*)&buf[0]; data = *ptr;
here, I except data = 0x0102, but actual output is data = 0x0201. Why swapping of bytes takes place here ? Any Idea ? Please guide me how I can achieve excepted answer ?
