Hi
I hope someone here can help guide me.
I'm using a custom designed board which uses the same SDRAM memory configuration as the ST32429I-EVAL board.
In the Keil file system_stm32f427x.c I have uncommented
#define DATA_IN_ExtSRAM
so that the procedure SystemInit_ExtMemCtl() is called.
The very first line of this procedure is
/* Enable GPIOD, GPIOE, GPIOF and GPIOG interface clock */ RCC->AHB1ENR = 0x00000078;
This line causes a hard fault after jumping back to system_stm32f427x.s and then trying to jump to __main. If I comment that line out then the code jumps to __main with no problems.
The strange thing is, if I add a breakpoint to the line right after
// RCC->AHB1ENR = 0x00000078;
and then change the RCC->AHB1ENR register manually so GPIOD, GPIOE, GPIOF and GPIOG interface clocks are enabled the code runs fine into __main.
Even though the code now runs I haven't got the external RAM to work yet so this may be part of a bigger problem or a configuration problem.
I'm using an old version of uVision V4.71.2.0 so does anyone know if there were bugs in the Keil provided system_stm32f427x.s and system_stm32f427x.c files?
Any help would be appreciated.
I just realised I made a typo above, when I said "system_stm32f427x.s" I meant "startup_stm32f427x.s"
